Anyone interested in 83 Pace Arrow Tear down and Rebuild?
fulltimin
Started to look into some water damage in the kitchen of our 83 Pace Arrow. The more I looked, the more I found. I have some pics of the damage so far. Anyone interested in following a rebuild thread?
If you want to do something, you will find a way.
If you don't, you will find an excuse.
Good judgement comes from experience.
A lot of experience, comes from bad judgement.
8,452 REPLIES 8,452
fulltimin
What I did was to use a small round over bit in the router to correct that situation.
I wanted just a small round corner, so I used a 1/8" rounding router bit.
This is the bit I used, and it created just a small round corner.
The plywood here is only 1/2 inch thick, so you can see the round corner is not very large.
fulltimin
Finally! Managed to make it to the motorhome today.
If you remember, I was working on the shelf below the rear window.
One of the things to watch out for is the corners of said shelf. Anytime wood has a square corner, it is very easy for the wood to be chipped off.
The solution is to round off the corner just a little bit. It will take a much better beating without chipping, than a square corner.
fulltimin
Nothing like having computer service calls interrupt you when you are trying to get work done. Ugh! The good news is, that provides more funds for buying goods for the moho!
fulltimin
Ah, yes. The wife was right. I needed a little time off.
Back to work this week. Wahoo!
fulltimin
Ah, yes. The best laid plans.........
I was informed yesterday that since the New Year is upon us, that we would be having a movie marathon New Years eve and New Years day.
Oops, my bad.
Then again, maybe it's the calm before the storm, before I get locked up in the motor home to finish it..... Lol.
Well, Happy New Year to Everyone. Hope your Holiday was a great one, and thanks for going on this journey with me...
fulltimin
Well, today was shot from 1 too many computer service calls. Hopefully, tomorrow.
fulltimin
The shelf will also fold down, out of the way when not in use, which will be most of the time.
fulltimin
I am also adding a shelf at the rear, under the window. That is roughly 12 x 24 and the wife can use that for holding her makeup and hair items while "puttin' on her "face", as she says.
fulltimin
Test fitting the rear window slide again. That is 1/2" plywood about 20 x 24, give or take a little bit. With the slides waxed, I can open and close the cover with my little finger without trouble. Takes little effort to move it.
fulltimin
I also widened the slot on the other side where the rear window cover will slide back and forth. Made that a touch over 1".
Not sure if you can see the extra saw cut there or not. Used my portable Ryobi to make the cut.
fulltimin
Finally had some time to work today. First step was to add some sealant in the corners of the shelving area that will be in the "bath" area - that's what I call the last 3.5 ft of the rear of the motorhome. The actual bath area is on the drivers side, and this is on the passenger side.
I wanted to seal the corners, just in case some extra moisture from the shower area migrates over to the other side, hence the extra seal. This area will also get some Por 15 to help keep moisture from getting into the plywood.
fulltimin
Wanderlost wrote:
fulltimin wrote:
Thought for the day/note to self..... When drinking soda from a 2 liter bottle, make sure said bottle is in an upright position before removing from the lips! ๐Ÿ™‚
Oops. Hope it wasn't too big a mess.
No, just enough that I had to change my shirt. One of those ... What was I thinking?, or NOT? Lol.
Wanderlost
Nomad II
Nomad II
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -- Mahatma Gandhi
Czarny, black cat
Rainbow Bridge: Spotacus, Alexander the Grrreat, and so very many more
fulltimin
Well, it looks like I'll be able to get back out there shortly and get back to working on the moho within a few days. Wahoo!
fulltimin
Bruce Brown wrote:
So is 2021 the year this thing finally makes its maiden voyage?
Hope so. Only 6 or 7 months behind schedule, so far.
