Bad Dog = No Start and No shifting of Transmission
Cubanredneck
Hello RV community,
So was about to leave on a trip and went around the corner with the coach only to find that the transmission would not shift. Checked the oil level and found it to be ok. For some reason decided to check under the coach to find that our dog decided to chew on the transmissions harness destroying 80% of the wires. I decided to splice the wires back together to see if this could get me to the shop but it didnt work. After splicing all the wires(Color Coded) the coach would not start.Obviously it had to do with what I did since it had started before. after checking everything i found no issues with the splices so I crossed the starter and fired up the coach. I had no choice as i was on the side of the road. My question is to all can the harness be spliced? I was reading that since it sends signals any change in the wires resistance can cause a problem. I drove the coach over to a shop in first gear since it was only a mile away and waiting to see what he says. Hes a friend and felt that they could be spliced. Does anyone have a wiring manual for a 2007 F53? Is the transmission a standalone harness or do i need to replace the entire harness? The shop is backed up and could take a week before he looks at it. If i could find a harness id replace the entire harness just in case.
BTW the Tow/Haul light is now flashing and the speedometer no longer works. Im assuming its the computer coding out. Ford requires a special computer from what im being told to read the codes.
Any help or advise would be greatly appreciated.
Danny & Ali
Daniella Grace & Abigail Hope
Storm the destructive American Bulldog
2007 Itasca Sunova 35J.
2011 Ford F150 4x4
2017 Honda CRV
19 REPLIES 19
zigzagrv
Also NO special computer to read the codes on your V10. Almost any code reader will work. To reset the codes, disconnect the battery for a while. Good luck!
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
SidecarFlip
A lot of functions the ECU sees and controls are impedance related. Cut and splice can cause resistance issues and malfunctions. Think I'd pony up for a new harness and muzzle the pup.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
rgatijnet1
It's unfortunate that you had to deal with it like that. I just never trusted crimp-on connectors, especially on electronics. Soldering the wires together and using heat shrink tubing as insulation will be a lot easier than changing a wiring harness.
Cubanredneck
Thanks didn't think about that. Unfortunately i was on the side of the road so no solder just crimped on butt connectors.I figured i would replace the harness if it was not too expensive.
Danny & Ali
2011 Ford F150 4x4
2017 Honda CRV
rgatijnet1
Sometimes after an incident, all codes have to be cleared and the memory reset before things work like they are supposed to work. Of course this assumes that your splices were all correct and the solder joints were all good.
