Bypass valve position 2006 travel supreme
captron33
2006 travel supreme motorhome. I have had it since new. Today while trying to winterize
The cold lines worked ok, but the hot lines would not take the pink stuff.
Does anyone know the correct position of the 2 bypass valves, normal and bypass positions.
Thanks
5 REPLIES 5
captron33
Thanks Lou.
sailor_lou
As cavie identified, the pic shows the valves in the "normal" lineup, which is the water heater inlet open and the bypass secured. If you reposition both valves, the heater should be bypassed. If you still have an issue then it is possible the inlet valve isn't closing.
Lou
05 Travel Supreme Envoy
captron33
I tried that position and still had fluid running out the hot water tank drain. Do you think the valve failed?
cavie
sailor_lou wrote:
I recently posted a pic of the heater isolation and bypass valves on the iRV2 Travel Supreme Owner's Group Forum. You can see it here (Post #28):
Water Heater Valves
Hope this helps.
Lou
Note, that picture is "inuse" not "bypass".
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
sailor_lou
Water Heater Valves
Hope this helps.
Lou
