Coleman 13.5 air conditioners
wny_pat1
My Coleman 13.5 A/Cs are almost 20 years old. The current outside air is 78 degrees. My front air blows 52 degrees and my bedroom air blows 49 degrees. Is that in the right range of what they should be doing?
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
3 REPLIES 3
wny_pat1
MountainAir05 wrote:
What is the return air temp.
Had to be in the 90s as the coach had been closed up. Outside humidity is 53 right now. Just installed brand new filters and cleaned the condenser fins.
wolfe10
Very good numbers. Assume it is not real high humidity-- you wouldn't get those numbers down on the Gulf coast-- too many BTU's being used to remove moisture.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
MountainAir05
Sound good, keep the return air filters clean. What is the return air temp.
