Coolant Bleeder on Cat 3126
Ranger_Smith
Getting ready to do coolant system clean and flush. Going to do thermostats, rad hoses,clean and refill with Final Charge Coolant. Been looking all over thermostat area for air bleeder for cooling system and I don't see one. I have a small hose that goes from thermostat housing back to overflow tank. Will this system automatically purge the air out or is there a bleeder and I'm just not finding it.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
2 REPLIES 2
sailor_lou
In addition to the one on the T-stat housing you may find additional small hoses from other high points on the engine/radiator. On mine there are at least four other points and when I did my coolant replacement, there was nothing to manually bleed. Good luck.
Lou
05 Travel Supreme Envoy
wolfe10
Yes, if there is a hose from top of thermostat housing to overflow tank, that will serve an the air bleed.
Works best if you fill slowly.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
