Just finished a trip to Florida and have had a hard time diagnosing a coolant leak (per previous posts). I found the leak. When I took the doghouse off (2015 Fleetwood Storm with Ford Triton V0 engine, I noticed fluid leaking from the end of the water jacket on the right side. Any thoughts.... My plan is to take it home to Massachusetts, filling when necessary, and bringing to a Ford repair facility near home who I trust. Warranty will take it from there. Smart move or Stupid move... Feel free to comment. Thanks McD
Sounds like you are talking about the intake which is on top of the block in between the cylinder heads. Likely the gasket, but some of the 4.6/5.4 intakes were known to crack. I think your intake is very similar.
Intake gasket and cracked intake will require removal and reinstall.
Take a pic and post it and we can help you diagnose it.
The leak appears, small bubble and wet, under the gasket between the water jacket assembly on top right at the last bolt holding it down, I put a socket on it and it did tighten but to no avail. I also tightened three others on same side, Still seeping.
water jacket? are saying the radiator? if so find a repair shop in the area. this could be a easy job or a blow out on the way home. and double check its not a loose hose etc. seems to new a rv to have a major leak.
