DASH AIR FITTINGS?
tstryk
I have an 06 HR Scepter. Was going to recharge the dash AC, opened up the back, and saw NO fittings. Where could they be hiding? On my old MH the fittings were within a foot of the compressor. Any suggestions?
2006 Holiday Rambler Scepter 40PDQ
2014 Ford Fiesta frog
Tucker the schnauzer, Buddy and Cooper the labs
5 REPLIES 5
tstryk
Got it! The fittings were right there where you said....up front by the generator. I now have some nice 60 degree air! THANKS!
tstryk
Spizzer wrote:
X2. On my Freighliner DP, when I open the front where the genny is, the A/C fittings are staring me in the face.
jeff
Will check that out in a few - NOTHING on or near the compressor - even picked up the access panel in front of the closet - nothing there.
Spizzer
gatorcq wrote:
You say you open the back. On a Freightliner chassis, they only supply the compressor. The dash AC was installed by the coach manf. The unit is normally installed up front. Do you have a dash hood outside? If yes open it and look there. look for the dryer, evaporator unit.
jeff
Jeff
Retired AF, retired contractor, really retired!
2007 Winnebago Journey 34H 350hp Cat
2005 Jeep Grand Cherokee Toad with Air Force One
gatorcq
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
dougrainer
Up front at the Evaporator area. Are you positive there are NO fittings ON the compressor? Some Oems, have fittings at the rear and at the front. Doug
