Dometic RM2862 Bit the Dust
RV_CONUS
After 7.46 years, and one new cooling unit replaced under warranty, the Dometic bit the dust. The second cooling unit is gone.
A new residential fridge is going in on Wednesday.
Knew it was coming, not happy about the quality, but happy it is going.
The new fridge, has more room in both compartments.
2006 Allegro Open Roads 34WA
2015 GMC Terrain
2009 Blue OX Aventa LX
2009 Brake Buddy Classic
17 REPLIES 17
ronfisherman
Moderator
Moderator
We attended a Hartland open house a couple weeks ago. Some of the new 5th wheel units had residential fridges in them. They had two 12 volt batteries feeding a 1000 watt pure sine wave inverter. This is all they had power on 14 and 20 cu ft fridges. Most of the smaller fridges draw 300 watts to cool. But when cool do not run all the time. Not sure about starting though.
I am going to run with only 2 batteries until I find out I need more. My motorhome has a auto start on the generator. If the batteries get low. Generator will start and recharge batteries.
The real battery hog is our furnace. 2 batteries will not run furnace overnight in 30° weather.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Dog_Folks
Nutinelse2do wrote:
Dog Folks wrote:
Replaced our fire starter Dometic last summer with a residential.
Best thing we ever did, more room.
You are going to love it.
Your sig says you are full timers. Do you travel a lot? If so, how do you power the fridge when traveling? We are only going to have 2 Trojans, a Honda 2000 gen and an inverter that runs our " electronics center " what do you do about powering the residential fridge when you are on the road for a longer period? We have been having this discussion but DH doesn't think we will have enough battery power since we don't have a battery bank like our old DP.
Thanks in advance
It really depends on your type of travel. Traveling one day at a time should not be a problem traveling without power on the refrigerator.
Yes, we travel frequently. However, we do not boon dock. We are on the road 3-4 hours between campgrounds without power. If you keep the door closed, the refrigerator will hold it's cold just fine.
We know from our life in Florida, with it's frequent storms and power outages, a residential frig will go 24 hours if the doors are not opened.
That is our real world experience. Hope it helps.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
Lobstah
Depends on how long you're going to go between plugging in.
If you're going to drive for 15hrs, probably need some generator time in there to keep the Sea Salt Caramel Hagan Dasz from going soft 🙂
Jim
2005 Pace Arrow 36D
Very Understanding Wife
1 Boxer 😞
3 Maine Coon cats
Nutinelse2do
Thanks in advance
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
Dog_Folks
John S. wrote:
I wonder f the absorption manufactures are feeling the heat. Lots of residential units going in. Love mine and wish I did it long ago.
I agree. I also blame the absorption manufactures. They deserve the loss of business, because they cannot or will not build a unit that is safe and or provide a viable fix for those already in the RV'S.
When any company fails to meet the demand for safe, usable products they will eventually fail, and they deserve to.
When we got rid of our "fire waiting to happen," my wife said:"You don't seem upset about spending the money to get a residential unit."
I replied it was worth it for the piece of mind alone.
Our Rig:
John_S_
John
2015 Born Free Royal Splendor on a Ford 550
2018 Rubicon
Boo Boo a Mi Kie
42' 36' & 34 Foretravels sold
2007 Born free 24 sold
2001 Wrangler sold
2012 Jeep Grand Cherokee Overland sold
Susie Dolly, Lolly &Doodle (CKC) now in our hearts and thoughts
ronfisherman
Moderator
Moderator
RV Volunteers CONUS wrote:
Just going to use the same 110v plug.
Not going to install an inverter. The way we now RV, we have power available most of the time. We don't do a a lot of boondocking anymore, and the dry camping we do when traveling; the generator will provide sufficient power to keep the residential fridge cold.
Good plan. We already have a inverter. It should be OK for our travels.
RV_CONUS
LynnandCarol wrote:
That seems like a short life for the Dometic Fridge!
It was a short lifespan when the first cooling unit went out during the first year.
I'm surprised the second one lasted 6 years. The older units never gave us a problem......At least with the residentials, they can be replaced at about half the cost.
2015 GMC Terrain
RV_CONUS
ronfisherman wrote:
Thanks. That's the same model DW has on top of her list. With our RV there is a problem with wall on right side of fridge. Whirlpool says there needs to be 3 1/8" clearance on hinge side of fridge. We have 1 1/2". May still go with this model and move hinge to left side.
Any info on how you are powering it.
2015 GMC Terrain
ronfisherman
Moderator
Moderator
Dog_Folks
Our Rig:
RV_CONUS
ronfisherman wrote:
Our MH has the same fridge. Any info on what you are putting in to replace it.
Our is now 10 years old. Still original.
Whirlpool
2015 GMC Terrain
John_S_
The reason all these fridges cooling units are not lasting as long is the EPA mandated less sodium chromate be used. That is what protects the cooling unit from the gas inside eating the pipes. It seems that we are seeing more of this in the newer units while the older ones are going strong. I know I decided to pull mine and put in a residential.
John
2018 Rubicon
Boo Boo a Mi Kie
2001 Wrangler sold
AZPops
I guess, my side by side Dometic lasted 12 years. Luckily I found a great mobile tech while we were in Adelanto to do a rebuild. However, after making the repair, I feel that I should have had him install a residential frig at that time.
Pops
