โOct-24-2017 06:08 AM
โOct-28-2017 07:12 AM
mfitz709 wrote:
thanks for all the advice, taking it to my rv mechanic next Tuesday. He believes its the power converter going bad.
โOct-27-2017 10:06 PM
โOct-27-2017 03:53 PM
โOct-24-2017 07:25 PM
wgriswold wrote:gutfelt wrote:wgriswold wrote:
I had the same problem and it was a failing 30 amp fuse holder next to the pos post on the battery. Eventually it got burned enough to completely fail and then I found it. I replaced the fuse holder and the problem went away.
there wont be any 30 amp fuse holder that has anything to do with a 50 amp 120V system cutting in and out
No, 30 amp was mine but there might an analogous failure here.
โOct-24-2017 05:33 PM
โOct-24-2017 05:30 PM
โOct-24-2017 04:13 PM
โOct-24-2017 03:39 PM
โOct-24-2017 08:55 AM
mfitz709 wrote:
Drew its 120 volts at the house. Even when plugged in to 50 amp service it does the same..
โOct-24-2017 08:51 AM
โOct-24-2017 08:20 AM
โOct-24-2017 07:37 AM
โOct-24-2017 07:22 AM
mfitz709 wrote:
Not a breaker, I've looked for a short with no luck.
โOct-24-2017 06:18 AM
