electrical problem Help
mfitz709
Our coach all of a sudden loses land power for no reason and then in a few minutes comes back on! Not a breaker, I've looked for a short with no luck. Any ideas would be welcome, has this ever happened to anyone?
It kind of messes up our camping. Help please.
Mike, Judy, & Izzy the spoiled dog.
2005 31'Fleetwood Jamboree
"Do not follow where the path may lead. Go instead, where there is no path and leave a trail." Ralph Waldo Emerson
14 REPLIES 14
gutfelt
mfitz709 wrote:
thanks for all the advice, taking it to my rv mechanic next Tuesday. He believes its the power converter going bad.
as tinstar posted its nothing to do with converter at all>> best get a different RV mechanic if he told you that
forgot to ask does it do this on several different Rv shore power sources or did you only try one?
Tinstar
A power converter just converts 120 volts to 12 volts. I don't know how that could be causing you to lose all 120 power in the coach unless it's shorting something out. If it was doing that, I would think you would find a thrown breaker.
:CNever pass up a chance to go somewhere:C
mfitz709
gutfelt
wgriswold wrote:
gutfelt wrote:
wgriswold wrote:
I had the same problem and it was a failing 30 amp fuse holder next to the pos post on the battery. Eventually it got burned enough to completely fail and then I found it. I replaced the fuse holder and the problem went away.
there wont be any 30 amp fuse holder that has anything to do with a 50 amp 120V system cutting in and out
No, 30 amp was mine but there might an analogous failure here.
no or at least I don't see the comparison
doxiemom11
Our EMS would frequently cut power because of low voltage or power surge. Called power company, they found something bad with the power source at the power pole - their wires and fixed it and we didn't have problems after that. It could sometimes be 3-4 times a day.
wgriswold
2016 Ram 2500 4x4 Laramie
Arctic Fox 25Y
gutfelt
wgriswold
Arctic Fox 25Y
gutfelt
mfitz709 wrote:
Drew its 120 volts at the house. Even when plugged in to 50 amp service it does the same..
STBretired I believe is on the right track I bought a 2008 allegro bus 7 years ago; the first winter my power would go off and back on
for no reason; that summer I had a look in the ATS wiring and found the neutral was loose and had gotten real hot; repaired the wire and never a problem since
STBRetired
Examine your shore power cord closely for signs of heating which would indicate a poor connection or broken wire inside the cord. Pay particular attention to the plug itself looking for loose prongs or sign of heat.
Follow the cord to where it ends inside your MH. Look to see if you have an EMS system installed (Progressive Industries, SurgeGuard, etc). That might be sensing a voltage problem, or might be defective and false triggering. If you don't have an EMS, then the shore cord should connect to your ATS. There could possibly be a failing contactor or control board in the ATS. There could also possibly be a loose connection inside the EMS (if you have one) or ATS where the power cables connect. Make sure you disconnect from all power before you check those connections.
How frequently does it do this? Can you have someone listen to the ATS to hear if the contactor drops out when the power fails?
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
mfitz709
DrewE
Is this 12V power (lights and stuff) or 120V power?
If it's 12V power, possibly there's a self-resetting circuit breaker that's cycling either from an overload or because it's old and worn out.
Sam_Spade
Not a breaker tripping but maybe one going bad.
You NEED a meter to find out exactly where the power is disappearing.
It would not be a short you are looking for but an intermittent OPEN, a bad connection somewhere.
But if you have a power management system, the previous post applies. I would think/hope that if that was the problem that that system would make some alarms or light some warning lights.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
10forty2
Sounds like you may have a electrical management system that is sensing a bad current source and is shutting it down to protect your RV. The EMS could also be bad. Or, you could have a bad transfer switch.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
