eletrical problems
eugene12
I have a 1996 dynasty monoco. My air conditoner over head lights is not working. But my outlets and appliances are working. Any suggestions about whats going on?
14 REPLIES 14
msmith1199
The question was, "My air conditoner over head lights is not working." Is it just the lights, or is it the lights and the air conditioner?
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
MrWizard
Moderator
Moderator
Question are you on shore power
Or generator power?
All over head lighting quit
Or just some of it
Our 96 Safari, has 120vac lighting in kitchen and dining and incandescent wall sconces which used to have 60w light bulbs in them,
Two 40w fluorescent tubes for the kitchen work area
Center line ceiling lights are 12vdc
The 120v lighting is all on the inverter output circuit
If you are on generator ... reset both circuit breakers on the generator
I can explain it to you.
1997 F53 Bounder 36s
wa8yxm
Lights inside a Motor home are normally 12 volt DC devices, I need to ask what else is not working.. Suspect list includes slides and water pump, the fridge and water heater and furnace and fans.. All use 12 volt either for operational power or control power.. Likewise if the air conditioners have remote thermostats (by remote I mean wall mounted OR wireless remote controls) then they use 12 volts for control as well.
Everything not working is 12 volts.
Suspect#1: Your battery disconnect (Salesman) Switch..
Suspect #2: Dead house battery
Suspet #3: Dead or disconnected converter (This can be due to a tripped breaker or in a very few RV's tripped GFCI)
and if only SOME of your 12 volt stuff has failed....
Suspect #1 blown fuse #2 bad junction connection or wire.
wa8yxm
Passin Thru wrote:
Try your GFCs and see if one tripped. Use a test light and check your outlets.
He has no 12 volts.. His 120 volt outlets are working, Do you wish to re-think?
popeyemth
eugene12 wrote:
The breakers in the panel box has the right voltage.
Then look for DC voltage at the thermostat
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
backhoemike
when mine was doing it was was a 5amp fuse on a selnoid over by where my shore power hooks up took me 3 wks to find...
eugene12
eugene12
popeyemth wrote:
But did you use a meter to see if AC voltage is getting THROUGH the air conditioner breaker?
Good Luck, Mike
the breakers in the panel box has the right voltage. Thanks
popeyemth
Good Luck, Mike
Passin_Thru
eugene12
popeyemth wrote:
Try the fuse box/breakers?
fuse box has correct power,
eugene12
newman fulltimer wrote:
You lost 12 volt supply somewhere
you mean a 12 volt dc supply
popeyemth
newman_fulltime
