I have a 2008 HR endever with a 35 foot slide. I,m having trouble figuring out how to remove the slide awning. It has cross bars that hold the awning material up. Their at least 5 under the awning material. If I unbolt the awning from the out side they will not let me lift it and set it on top of rv to get at the seal. Thanks Dan
Good info Thanks. I can see that the metal clip inside the seal rusted and cause mine to come off. I plan on using liquid nails as glue and sealant to keep it from rusting and coming off. Did you use any glue ? Thanks Dan
You have to unbolt those support arms as well. Once you take the slide cover loose and lift it up, you will see how those support arms come loose. Doug
