New lift motor or new lift arm. Had that issue with mine. For a temporary fix, I was able to shim the motor assembly up a bit in the plastic mounting housing which got it to work. Permanent solution we replacement of lift arm assembly.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
