flat towing 2004 honda accord auto trans
priestlake
I plan on flat towing a 2004 Honda accord auto trans, any suggestions. I have heard that not to exceed 60 mph and follow the tow procedure exactly.
4 REPLIES 4
Clay_L
This is redundant since the other posters have it right but here is a copy of a letter I received from Honda in 2002. I think 2005 was the last year Honda okayed 4 down towing for the Accord.
Dear customer:
Regarding your inquiry on towing your Honda or Acura automobile behind a motorhome:
For your vehicle, the Owner's Manual advises against towing at more than 35 m.p.h or for more than 50 miles. However, this recommendation exists primarily because Honda has not conducted formal tests at higher speeds and for greater distances.
We are not aware of any particular problems being caused by motorhome towing of Honda/Acura automobiles with either manual or automatic transmission, so long as proper pre-towing preparations are made and the vehicle is towed at legal highway speeds.
Manual Transmission
When preparing to tow your vehicle, make sure the transmission is full of fluid. Do not overfill.
โ€ข Release the parking brake.
โ€ข Shift the transmission to Neutral.
โ€ข Turn the ignition key to the ACCESSORY (1) position to release the steering wheel lock. Make sure that the radio and all accessories are turned off.
Automatic Transmission
When preparing to tow your vehicle, make sure the transmission fluid level is full. Do not overfill.
If Honda/Acura automobile with an automatic transmission is towed with the front or all four wheels on the ground, you must do the following every day immediately before towing:
โ€ข Start the engine.
โ€ข Press on the brake pedal. Shift the lever through all the positions (P,R,N,D,2,1).
โ€ข Shift to D, then to N. Let the engine run for at least three minutes, then turn off engine.
โ€ข Leave the ignition switch in ACCESSORY (1) so the steering wheel does not lock. Make sure the radio and any items plugged into the accessory power sockets are turned off so you do not run down the battery.
If you travel more than 8 hours in one day (including stopping time), you must stop and repeat the above procedures.
NOTICE:
The steering system can be damaged if the steering wheel is locked. Always leave the key in the ACCESSORY (1) position to prevent damage to the steering system when towing behind another vehicle.
CAUTION:
Severe automatic transmission damage will occur if the car is shifted from reverse to neutral and then towed with the drive wheels on the ground.
NOTICE:
Improper towing preparation will damage the transmission. Follow the above procedure exactly. If you cannot shift the transmission or start the engine, your vehicle must be on a flat bed truck or trailer.
If you tow a Honda/Acura vehicle with automatic transmission, the fluid must be changed every two years or 30,000 miles, whichever comes first.
Although experience has shown that the Honda/Acura transmission and powertrain are capable of being "motorhome towed", America Honda does not assume responsibility for any vehicle damage or liabilities incurred due to the towing device, towing vehicle, lighting hookup, or other towing equipment or towing procedures; any responsibility for these items is assumed by the owner/operator.
If you have additional questions, please call American Honda Motor Co. Inc. (National Consumer Affairs) at 800-999-1009.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
crasster
It should tow just fine. 60mph is standard for the speed. Think of "standard" in quotes and define it how you like. ๐Ÿ™‚
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Fiesta
Ditto above on my 07. 10k no problems. BUT check each other!
tommy_g
I have towed my '05 about 65,000 miles with no problems. The old Bounder and I both like about 300 miles per day at around 62mph. Always put the transmission in neutral from drive(not reverse!) and turn the key off to the last position (steering unlocked). I always crank her up for a few minutes when we stop to make sure everything is ok.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
