fuel filters
ggrotz
have a 2005 pacearrow 37c 8.1 workhorse engine.I have been told that there are two inline fuel filters,one in rear by the gas tank and the other in back of the drivers seat on the inside frame.I would appreciate information on this.Thank you
1 REPLY 1
cmarq
I have a 2003 and there is one just behind the rear axle oh the left side. you will have the new style it has a inlet and outlet before 2003 they used a filter that require a adapter that one is no longer available and requires a conversion kit which is very expensive. You can get the filter you need at NAPA I use the NAPA gold #3481 about $14.00 it is made by Wix #33481 AC Delco is GF652 Fram is G3727. The Napa gold by Wix i s a good quality. There is a web site "OMEYS" that has a lot of good info for workhorse and part numbers, they also have a DIY section I used the plans there to make a trac bar which stopped the tail wag on my 37ft Pace Arrow. Hope this helps
