Nov-29-2019 08:26 AM
Nov-29-2019 08:55 AM
rgatijnet1 wrote:
The power issue is either a GFI outlet that has tripped or the inverter. These are the outlets with a red reset button on them. You may have only one or two on your coach.
The other thing to check is the circuit breakers on your inverter itself. Most usually have two circuit breaker buttons that can trip. These are on the inverter and NOT in your main circuit breaker power panel.
I should have added that your salesman switch, usually by the door, may have be switched off which would keep 12 volts from going to either the WH or the furnace. With no 12 volts, neither will work.
Nov-29-2019 08:53 AM
majordad wrote:
Need help, 1800 miles from home, I have lost the 120 volt power on passenger side of my 2001 Fleetwood Discovery and the propane does not work to the heater or refrigerator. The other day I started the coach as the batteries were low and let it run for about 15 minutes. I also Reset the a/c out 1 and 2 on the inverter and when I checked the bathroom lights, they came on. I releveled the coach and shut off the engine. As it got dark, I turned on the heater and it was working fine. Came back later to put the boys to bed and heater was blowing cold, ignition failure on the hot water heater and again no lights in bathroom..
Any advice as to what is wrong, we need the heater going home as it will be colder.
Merrill
Nov-29-2019 08:38 AM
Nov-29-2019 08:35 AM
