Heart Inverter doesn't charge batteries
vegasfoodguy
I have Heart Freedom 15 inverter in 1999 Diplomat. When shore electric is hooked up, The batteries show dead. after driving for several hours, the inside remote shows the batteries dead. The built in charger-converter doesn't seem to be working. The hydrometer shows recharge, just below good. All 24 cells show the same (4_6v) none dead.
I know, kind of confusing.
Thanks,
Terry
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
16 REPLIES 16
MrWizard
Moderator
Moderator
Did you check the push button circuit breakers on the front of the inverter
What happens if you turn it off, and disconnect the batteries wait five minutes and reconnect and turn on
I can explain it to you.
1997 F53 Bounder 36s
Mandalay_Parr
Suggest you get an electrical person to help check it out.
There are fuses, circuit breakers, disconnects, and wiring involved in addition to the inverter charger itself.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
