Does anyone know where to locate the hydraulic reservoir on a 2005 Itasaca Sunrsie. Not sure where to locate and there was nothing in my manual as to where it's at.
Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
2005 33' W20 Itasca Sunrise the hydraulic fluid reservoir is right behind and below the drivers side door. It's easiest to check it by moving the living room slide all the way out. You can then see and reach around to it. The reservoir cap has a fluid level dip stick attached to it and the cap just screws out and back on. the fluid level should be up to where the neck of the reservoir that the cap screws onto attaches to the reservoir itself.
