Jacks on a 1992 Bounder
mercedesme28
I have hydraulic jacks to level my rig, they are on the floor next to the driver seat and I control each one With a lever
They have worked fine however today I turned the switch on and the lights come on but I get no movement, the jacks don't move,no noise,nothing
I checked the fuse and it's fine
Where do I look next ?
Thanks
7 REPLIES 7
dougrainer
This is your best bet. It has a guideline and pics. Doug
http://www.hwhcorp.com/ml23934.pdf
Gjac
Are the HWH jacks 200 series? If so I would look in the engine compartment it should be a black box right in front of the radiator. But I doubt that low fluid is causing this problem. If you go to their website they have a good troubleshooting guide there. That will get you started and you could post back what you find after going through the troubleshooting steps.
mercedesme28
Any clue as to where the reservoir is located
mercedesme28
Where is a hydraulic fluid reservoir located
mercedesme28
I checked the fuse next to the levers
Where were the other fuse be or hydraulic fluid container
I was once told by somebody that it might be transmission fluid and not hydraulic fluid is that possible
cj7365
There is a fuse up by the hydraulic motor, did you check that one?
blazenpm
I have a 1989 Bounder with the same levelers. Check your fluid level in your reservoir. Also, check your fuse where your leveler handles are.
