Leaking. Help?
reinita
Hi. Camping with a full freshwater tank, but it is now leaking. Water is dripping steadily.
We have a 3170 Forest River Sunseeker.
https://t.co/Jm6AvC1G7z
It's coming from the yellow/tan twist-on piece on the top left. This is in the outside cabinet under the bunk beds.
Pump is off. The valve at the bottom of those hoses is in the shut-off position.
Any other ideas? At this rate, we'll be without water in a day or two with no way to refill.
We're not handy either.
Thanks!
Forest River Sunseeker 3170 bunkhouse. We travel with a Leonberger, a 22-year-old, 19-year-old and 12-year-old.
6 REPLIES 6
Bobbo
Is it leaking from the threads, or from where the hose attaches to the cap's other side?
Bobbo and Lin
ronfisherman
Moderator
Moderator
Looks like it is cross threaded. Remove it and see if it can be threaded on straight.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Harvey51
That cap looks like it isn't on straight.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
DrewE
Any idea what this thingy is, or where the pipes connected to it lead to?
Since tightening the yellowish bit didn't help, the next logical step would be to undo it and examining the washer or O ring that (presumably) is supposed to be sealing the connection, check the connector and plastic body of the doohick for cracks, etc. Unfortunately, from the sounds of things, this isn't practical to do with the tank full, unless you can locate some shut-off valve that stops the dripping.
reinita
I did, with no noticeable change in the dripping.
bamcote
Clicky. Can you tighten it up?
DH, DW, Tildie, Bella and
Molly the Maine Coon
and Greta the shorkie pup
2008 Fleetwood Bounder 36Z
2007 Saturn Vue AWD with Ready Brake Brute
