leaky air system 2002 damon
woodroe
Hi This my first post here. My 2002 damon escaper is loosing air pressure while parked and not running. The front air suspension sags but the rear stays up. Air gauges go from 120 psi to 50psi in 5 to 7 days while parked. while running air pressure returns to normal in minutes. Where should I start ?
2 REPLIES 2
blangen
Actually, my 2004 Escaper deflates substantially in about 3-4 days... as it's supposed to. No problem, here. I'm assuming your 2002 is not much different.
wolfe10
While that drop is considered normal, the place to start if this is worrisome to you is to use soap solution on all air line connections with the PSI at 120, engine off.
Be sure to use jack stands so you are safe under there.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
