Lets talk about the diff between 19.5 and 22.5's on Gassers
Txsurfer
Aside from IMO better looks what are the benefits to units with 22.5 wheels on Class A gas units? Can you convert a 19.5 set-up to 22.5's?
2017 F250 PSD 4X4
2015 Livin Lite Axxcess 24FBA
2016 Honda Pioneer 1000-5 Deluxe
19 REPLIES 19
MrWizard
Moderator
Moderator
Chassis weight, tire wear
And no, i don't think you can get 22.5 to fit your 19.5 RV
Unless you want to try and lift it up to look like a Monster Truck
Price is significant higher per tire
Just read some of the tire threads taking brands and pricing
I can explain it to you.
1997 F53 Bounder 36s
wolfe10
Ready2BRetired wrote:
If you choose to convert keep in mind you will be changing your applied axle ratio. Tire diameters are figured in as criteria in determining performance values beyond just the tire capacity ratings.
Yes, read that BIG change in effective rear axle ratio.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Ready2BRetired
10forty2
I would think that the 22.5s have a higher weight capacity, but that's ultimately going to be limited by your chassis rating. I would also think that the larger tires would ride significantly better and may wear a little better. As for converting them, there is probably an adapter that would need to be used to attach to the hubs. With that alone, I would NOT want to convert. Anything that needs an adapter becomes a weak point.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
mike_brez
Carry more weight
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
