LOST POWER
Brodie1234
OK folks...I have a 40ft Desiel Motorhome (Alpine Coach)
Unit sat for two weeks -- came back -- started unit, fine.
All Electrical items on Coach fine - everything worked like a charm.
Started generator to exercise it -- power transferred over fine and Gen ran everything fine for the hour exercise.
THEN, today, two (2) days later in the PM I lost Power --- I do have a Surge Protector at the pole. Green light on -- reset breaker at pole. Protector cycled fine -- still no power inside.
Also checked and reset all breakers inside -- all fine!
Started Generator -- could hear the trasferswitch kick BUT no power produced.
Remember, two days prior -- everything worked perfectly
What has happened here -- could my 50amp breaker be bad
Advice needed
Thanks
16 REPLIES 16
AllegroD
Have you checked main CB in the (inside) electric panel? Also, if you have an inverter/charger, the CB on it flips and the pass through stops.
1492
Moderator
Moderator
Moved from Forum Technical Support
