My 2011 Winnebago Vista 35F has 1-1/2 baths. The 1/2 bath has its own black tank with a macerator pump to pump the waste to the dump. I can open the valves however only a trickle of water comes out - then NOTHING. The macerator pump runs with - but nothing is coming out! We think it could be several thins - 1) the dump waste valve is not working - 2) there is a blockage from the valve to the macerator - 3) the macerator pump needs to be serviced. Has anyone experience this issue? Any assistance would be greatly appreciated!!!!
this may be too simple but did you check that the cap is off of the end of the macerator hose? don't ask me why I know that can happen.
Dave & Kathy 2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike Fulltime 2007 to 2016, now halftimers Before you give someone a piece of your mind, make sure you can get by with what will be left. Our Blog National Parks Visited
Hi thank you - Yes there is/was plenty of water and 'material' in the tank. We had someone remove the material (similar to a porta potty truck) then we put another 5 gallon bucket of water down the toilet to see if they 'may' have removed the blockage - still no luck. When using a flashlight to look into the tank - we can only see straight down. We have also tried to snake the toilet -again no luck.
