Magnum inverter/charger not charging batteries
janstey58
I am plugged into 10A A/C outlet with adapters to the 50A shore cord and not getting any charge to batteries. The transfer switch lights red when I plug in the 10A cord, but no power to the inverter. Do I need to have the Magnum inverter button "on" to charge?? Is there something I am missing, worried the batteries will freeze here with temps in the single digits. Thx! Jeff
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
4 REPLIES 4
FIRE_UP
janstey58 wrote:
Figured it out, I used a heavier ext cord to plug into 10A plug, so the voltage drop must have been too much with the lighter cord. Glad I am now charging in this frigid weather, thanks all!!
Jeff,
Glad you got it all figured out. You asked if the Inverter needs to be "ON" in order for your Inverter/Charger to charge the house batteries? The answer is NO. I also have a Magnum 2012ME MSW Inverter/Charger and I have plugged into 15A services many times and the Charger side of the Inverter/Charger has continued to charge the house batteries as normal. I don't know how much you know about your ability to control just how much your Inverter/Charger can put into your batteries at any given time but, in your Remote for that unit, you can limit the amount it puts out. That will draw less on your extension cord, even a smaller one. Just an idea.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
janstey58
Jeff and Kim
07blacktruck
Before I would spend much time looking for a problem that may or may not be there, I would plug in to a 50A outlet and see what happens. I would suspect there is an automatic switch in there that is not powering the inverter due to the lack of amperage available. A 10A service is way too small to run your MH. If the batteries are in decent shape, they won't freeze at single digit temps.
The inherent vice of capitalism is the unequal sharing of blessings;
the inherent virtue of socialism is the equal sharing of miseries. Winston Churchill
Bill_Satellite
You are plugged into a 10 amp circuit and wonder why you are having problems? You are not INVERTING anything. Inverting is converting 12V to 120V. Are you talking about CONVERTING? Using 120V to charge your 12V batteries?
Are you expecting to get things within your 50 amp service to work while connected to 10 amp service?
Please give us some additional details.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
