MH Tire Balance
bigred1cav
What should one pay for balance of each tire on a MH? Where is it best to have this service completed and what should an alignment cost on a MH?
17 REPLIES 17
trop-a-cal
If you use Equal for balancing you never need to have tires balanced, as it is a powder that moves to the spot needed as you drive down the road.
bigred1cav
bEEN ON COACH TWO YEARS 6 tires also how much would the bearings or whatever goes inside the tires cost to maintain balance?
DSDP Don wrote:
What type of motor home and are the tires new, soon to be mounted or already on the coach.
The alignment should be between $150.00 and $200.00. Make sure it's a 4 wheel alignment. They'll connect lasers to the rear wheels to make sure they're tracking the same as the front.
DSDP_Don
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
