Monaco PBD with Cummins
devildog1971
This 40 foot beast is new to me so I have been reading the manual one place it states that all Monaco Diplomats are wired for solar I can not find it. Another piece in the manual states that all monaco diesel PBD models have a two terminal wire under the dash for a C/B radio and on a outside view of all sides of the motorhome it even points to a antenna on the roof and describes it as a c/B antenna. No wonder I had trouble putting oil in the motor
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
1 REPLY 1
Scars
Hi, you might have better luck contacting Monaco user groups like Monacoers and Monaco iRV2 forums to get specific wiring info. Another possibility is an experienced installer of radios and CBs to see if they could spot the wires you need. Good luck.
'03 Monaco Monarch SE 31'
