Motorhome hitch receiver has play in it
becker
I have a 08 Monaco Dynasty..... the hitch is rated at 10,000 lbs.... I have a Roadmaster Blackhawk All Terrain 2 Towing system.... when I slip my Roadmaster hitch bar into the receiver on the coach, there is a little play left to right.... very little, maybe 1/16 to 1/8 inch.... a poster on this blog had the same problem.... he solved it by using another type of lynch pin.... after you inserted it you tightened a nut and it held the tow bar very tight in the receiver and it eliminated the play in the hitch (I may not be explaining the lynch pin correctly).... my question is: has anyone had this problem and solved it in this manner? Thanks
2008 Monaco Dynasty, 42ft, 4 slides, 425hp clean air Cummins diesel
2013 Jeep Sahara 4-dr w/M&G Braking System
Roadmaster Blackhawk 2 All Terrain Towing System
30 REPLIES 30
Effy
There are a few anti-wobble and hitch tightners on the market. I opted to drill and tap for a 3/8 bolt in the top of the receiver and I just snug it up after I hook up. Works fine although a little slop won't hurt anything either.
2013 ACE 29.2
