Mounting TV
Joan217
My 2018 Four Winds 24F came with cut out in bedroom for 32" TV already wired. My question is mounting, I have searched Forums and You Tube with no luck. Concerned that the opposing wall is the shower, do not want to run into problems when screwing in the hardware. Has anyone had any experience with this?
4 REPLIES 4
Joan217
Thank you, I am going to use Mich's advise and try to remove the covering to be sure where mount should be placed.
Dusty_R
Or use a density type stud finder.
tinstartrvlr
Could you mount it from the bottom, if the base of the cutout is sturdy enough?
Mich_F
My Itasca is pre-wired for a TV in the bedroom. My opposing wall is the shower also. I pulled the panel off the wall, where the connections are located and they put wood backing plates in the wall, where the mount should be installed.
Your MH most likely has something similar. You can feel around for signs of backing plates, or try to remove whatever is covering the area where your TV should be mounted, for a better idea of where the mount should go.
I just took a pic of mine, but I'm having issues loading it. You get the idea anyway. ๐Ÿ˜‰
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
