Hey folks,
I posted this in another forum and so far, have ZERO responses. The explanation below takes care of what I'm inquiring about. MY right front tire is becoming more and more noisy as we travel. As we have a long way to go before we return home, I seriously don't want to push my luck on this. So, any help would definitely be appreciated.
Scott
Gang,
We're presently on a trip and, will be camping in the southern Deaborn/Detroit area for the next couple of days and visiting the area. Our coach an '04 Itasca Horizon 36GD with the C-7 CAT, has developed a bit of odd tire wear on the outer edges of the right front. It's kind-a doing the same on the left front but, not nearly as bad. The tires, Michelin XRVs, 255 80R 22.5 are dated 3410 on all six and presently have over 45,000 miles on them. The pressure has always been correct based on the actual axle weight and, the Michelin tire chart.
The "odd" tire wear is in a form of cupping. It started on the outer-most tread and now, is progressing inward and is effecting the second-in tread. The wear bars are fairly close to being level with the tread but, not there yet. We've been "hearing" this cupping for well over a thousand to fifteen hundred miles now. The reason I've not done anything about this situation yet is, our route, which has been paralleling the top portion of the U.S. in Montana, N Dakota, Wisconsin, Minnesota and Michigan. And, in all that distance and places we've camped and visited, there's been ZERO places that carry and or service larger type RV tires.
So, at present, we're in Frankenmuth MI and, tomorrow will be heading down to the southern part of Detroit/Dearborn area. I'm hoping to get a lead on a place to purchase some tires in that area. Now, it's potentially possible that the coach may need an alignment too. I'll look into that when I speak with any tire folks I encounter and, where it may be possible to get one.
As for brand, I'm not brand loyal for sure. Not all that happy with these Michelins. I do have the inevitable sidewall cracking that's only been reported on here by most who own them. I don't pay much attention to those cracks due to the fact that Michelin says that's ok, as long as they remain within a certain size. Anyway, if anyone's got a line on where to look into some RV 22.5" tires in the Detroit/Dearborn area, especially in the southern part, we'd surely appreciate it.
If you're wondering why I did not do anything about this situation prior to leaving on this trip, it's because the cupping was so minute that it was almost non-detectable. If you ran your hand along the face of the outer tread, you, for the most part, could not really feel that cupping. It's only gotten worse in the milage mentioned above. And, I feel it's only gonna get worse and, I'm not in the mood for a blow-out, even before it happens. So, any history or, experience with businesses in those areas?
Scott
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
