Does anyone know what the button on the left door is for? There is no electrical connection just a little spring loaded button. The button is depressed when the door is closed. Thanks Don
There is a swing divider on the LH door that flips open and closed. Inside that divider is a 12 volt heat/defrost strip. Those pins supply power to that heat strip. Doug
