OBD PORT LOCATION - 2013 COACHMEN CLASS A
Drterry904
Hope someone out there has already tackled the location of the OBD PORT II ON 2013 COACHMEN MIRADA 29 class a Ford F53. I have a new 5 Star chip and cannot locate the port? Any help will be appreciated.
5 REPLIES 5
1492
Moderator
Moderator
Moved from Forum Technical Support
Drterry904
UPDATE ON COACHMEN OBD PORT LOCATION. I Read some of your post that sent me in the correct direction. Coachmen had the port "with cap" up loose in wiring right side if steering post. I pulled it down and tie-wrapped it is a easy to reach location. Thank you all for your help!!
pconroy328
By regulation it has to be within 'X' inches of the steering column. On all of my cars, they're within 2" of the column and attached to the bottom of the dash.
Easy to see once you know what you're looking for. But they're also usually black ports on a black dashboard! ๐Ÿ™‚
jhlady
Mine is attached to the steering column at the bottom. Had a rubber cover over it that says ODB II. My Mirada is a 2014 however, but I don't think they are that different.
Good luck! You will love the 5 Star Tune!
ADAD437
should be under the dash just above the steering column, hid.
James,Gail & Pancho
2005 georgie boy Pursuit
๐Ÿ˜›
