Onan Marquis 5000 how clean?
cm2785
Hey guys! I have a 1996 Bounder 34j with 11k miles and 400hrs on the Onan Marquis 5000 generator. I am curious how safe it is to run modern electronics on it. I have HDTVโ€™s, Computers, satellites, cameras, etc..
Thanks!
6 REPLIES 6
wa8yxm
How clean? VERY, not as good as a true sine inverter, but likely cleaner than shore power.. I've never had an issue with my 5500
NOTE: If it has not been exercised in a while (Should run 1/2 hour every month under 1/2 or load. or more in both 1/2s) you might want to run it an hour or two with non-electronic loads as cleaning up the power is ONE of the things regular exercise accomplishes
RLS7201
Passin Thru wrote:
They are safe because they don't use brushes. It is a brushless alternator.
Not exactly true. Brushes are used to excite the rotor.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Passin_Thru
MrWizard
Moderator
Moderator
perfectly safe, no problems about 'clean'
your modern electronics are less 'line' noise sensitive than the same thing built in 1996
in fact lots of electronics now make more 'hash' noise than older stuff
because of the switching power supplies in them
I can explain it to you.
1997 F53 Bounder 36s
Lwiddis
500 miles a year for 22 years. Wow
tommy_g
I have a 5500 that runs all of the above with no problems. I have more capacity with it than with shore power(5500w/120v=more than 30a). I would not be too worried with new electronics, since most of them have step-down power supplies.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
