rear window molding 2002 Dutchman
oceanbayrealty
There is 6 inch break in the bottom molding that goes against the glass. Is that normal? It doesn't look cut or broken.
3 REPLIES 3
bukhrn
Mine shrunk, but not that bad, I had about a 1 inch gap, I pulled it back together & super glued it, then it re-shrunk, pulling it out of the corners, then I put it back in place & just filled the gap with black RTV, as mentioned.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
Cloud_9
Yup, it is shrinkage. We have had some luck filling the space with black rtv . It is a seasonal thing, especially after a cold winter. You will need to redo it frim time to time. Just be sure that it is still in the channel, usually can be snapped back in with fingers.
Carle
darsben1
Shrinkage
Traveling with my best friend, my wife in a 1990 Southwind
