Feb-23-2020 07:42 AM
Feb-27-2020 05:26 PM
Feb-26-2020 07:02 AM
Feb-26-2020 04:27 AM
Gundog wrote:JoeH wrote:
I had broken gears in the gear case too. Take a look at the gear case bushings and the potmetal case that the bushings are pressed into. On mine, I found the bushings to be OK, but the potmetal case had wallowed out thus causing misalignment of the gears and tooth breakage.
I ordered a complete unit with a new gear case the motor also had that burn't electric smell to it.
Feb-24-2020 08:13 AM
Feb-24-2020 04:30 AM
Feb-23-2020 02:44 PM
Feb-23-2020 09:52 AM
Gundog wrote:Same as mine. It's been struggling to get over the hump for maybe a year now, and it's getting worse. I noticed the electrical conduit tube is touching the rail it passes through, an indication perhaps things are starting to droop.
It started by being very slow and hard to get back in. When my slide goes out it drops down at the end. When it comes back it has to raise about 3" - 4" then it used to come in fairly easy after it climbed over the hump..
Feb-23-2020 09:29 AM
2oldman wrote:
I'm having trouble with my biggest slide too. Did yours suddenly fail, or have you seen symptoms develop over time?
Feb-23-2020 08:55 AM
Feb-23-2020 08:53 AM
