Rubber gasket to deflect water on slide out
augustpilot
Has anyone tried a small rubber tape sticky on one side, comes in roll to put at 45degree angle to deflect water on slide. It is grooved so it will catch water and run to outside. I just saw this on a coach at the escapees rally in Gillette, wyo. owner told me he had a leak at bottom of bedroom slide out during rain. He put the above at the 45 top and bottom, both side of slide. Told me no more leaks.. If anyone has seen or tried, please comment. Thanks.
Jim
2017 Rockwood 2906WS Ultra Light
2014 Dodge Ram 1500 5.7. 4x4
Firestone Air Lift 1000, Equalizer Hitch
1 REPLY 1
ArchHoagland
My Monaco La Palma came with that from the factory.
A rubber strip on each side of the bedroom slide mounted diagonally.
Put it on and try it out. Worst case situation you can remove it.
Mine have been on for 7 years with no problems.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
