RV Winter use HELP
NewRVerOH
Hello, hoping someone can help. I am going to have to start storing my RV (Class A Fleetwood Southwind) in an unheated storage unit. My issue is we use it in the winter for tailgating football games. Previously it was stored in a heated facility so it was never an issue. My question is I need to have water etc kept warm inside the new non heated unit. Should I simply run the furnace in the RV? Is that sufficient for keeping everything warm enough? Should I put a heater in the RV for while it is sitting in storage instead. I do not want any pipes to freeze, etc but winterizing is not an option as I use it for tailgating. Any help would be greatly appreciated.
15 REPLIES 15
pianotuna
Nomad III
Nomad III
Hi,
Winterizing is an option so long as you are prepared to redo it. My record was 7 times in one winter.
Using propane to heat may not work unless an extra tank is hooked up.
Are the water tank and waste tanks in enclosed heated compartments?
Regards, Don
