Signal Lights / Others issues
DANO2014
DANO2014
ALLEGRO BUS 2002, ENGINE 330 Catapiller diesel ....
Attempt to turn on signal lights (right & left)will not stay on blinking. I can manually click it on and it works one time but will not stay on. My emergency flashers work OK and blink on dash???
Also notice my electric windshield shade does not work on drivers side & my power seat on drivers side does not work.
I have check all fuses I could find which is plenty but all seem to be OK.
Any suggestions or remedies would greatly be appreciated.
Thanks, DANO2014
DANO2014
Allegro Bus 2002
Retired: Cameron Iron Wks
U.S. Army Veteran
Louisiana Masons
2 REPLIES 2
DANO2014
Brought coach to RV dealer--Found out I do have
Two Flashers & one was not working! Other issues were
burnt fuses that I overlooked & a loose wire that
kept my power seat from working so I am back to
square one..... Plus he found my steps were about to
fall off- had two broken screws & also fix my Satelite
which would not pick up local channels !!
Appreciate all inputs as I have found this Forum to
be very helpful. I know just enough about this
electrical system that I may be dangerous !!
Thanks Again, DANO2014
DANO2014
Allegro Bus 2002
U.S. Army Veteran
Louisiana Masons
rgatijnet1
Check to see if you have a separate flasher relay for your turn signals. The other issues may just be dirty electrical connections.
