Slide out locks do not engage
JCMack
Hello to all. Today when I moved the front slide out in on my 06 mountain aire (gasser) in I heard a clanking sound then noticed the back slide out lock did not engage. Any thoughts on what I should be looking for to resolve this problem. Thanks
3 REPLIES 3
Passin_Thru
Mine is exposed and I use silicone on it once in a while.
imgoin4it
There is a magnetic switch in the bay for the entire slide that indicates the slide is in and can lock. Since the front lock engaged I would think that it is adjusted and working properly. There is also an I individual magnetic switch on and right behind each lock. That is where I'd look. I have gotten mine to work by tapping it with the handle of a heavy buyer knife when one was causing problems. Mine was replaced and now working good.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
koda55
Whenever my locks to do engage I have found my rv out of level. So far all I have had to do is retract the jacks and they engage.
