โMar-30-2014 05:17 PM
โOct-07-2016 07:51 AM
โOct-07-2016 07:42 AM
โOct-07-2016 07:32 AM
โOct-07-2016 07:30 AM
โOct-07-2016 07:18 AM
โOct-03-2016 07:43 PM
โOct-03-2016 07:22 PM
seal13il wrote:RobbieH wrote:
I didn't want bunk beds or the big entertainment center. You can get the entertainment center in the 33 also. I would rather have the overhead bunk, it gets used on over half our trips.
We wanted bunks for the little ones:)
โOct-03-2016 07:06 PM
Sites wrote:
After the stock water pump kept leaking under the bed, I ended up upgrading to the Shurflo Revolution that you linked. I also relocated it to the very rear lower, driver-side storage compartment. Some pumps are quieter than others, but the real improvement in reducing overall noise was getting out out of the living area. I mounted it using some rubber bushings and you can hardly hear it. Plus, if it ever leaks again, it will be in the exterior (waterproof) storage compartment. The biggest problem with our stock pump was that it was right against the water tank and the winterizing pipe would literally beat it like a drum when it cycled on and off.
I was able to use parts from Home Depot (hose, fittings, etc) and it took just a few hours. I would highly recommend it. Let me know if you would like me to post any pics.
โOct-03-2016 06:28 PM
โOct-03-2016 05:30 PM
mbacfp30 wrote:
The new ones are built off the XLT model instead of XLs...looks super nice. Still don't mind the bucket truck feel.
โOct-03-2016 05:29 PM
โOct-03-2016 10:09 AM
โOct-03-2016 10:04 AM
โOct-03-2016 10:03 AM
โOct-03-2016 09:47 AM
