transmission issues
bootdoc
I'm looking at a 79 revcon. The ad said the transmission had been recently rebuilt. I took it for a test drive and while on the highway it dropped out of 3rd gear at about 55 and stopped accelerating.
I pulled to the side of the road and shifted to 2. It moved moved forward fine. As I gained speed I shifted to D with no noticeable difference. Sounded like it was still in 2. I shifted between D and 2 several times as I drove it back to the sellers house. I could not hear or feel a change in gear. The owner sent text today saying it was a seal. Am I looking at possibly rebuilding the transmission? Is the seller not being honest?
16 REPLIES 16
Mandalay_Parr
Tell him you will consider After He gets the tranny repaired.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
rgatijnet1
If the seller is motivated, I'm sure he would not mind paying for a second opinion from a transmission shop that YOU chose. That is the only way to determine if the transmission is faulty.
I assume that he has documentation from the shop that did the work. If he does NOT have receipts for a compete transmission rebuild, I would walk away.
He might have just had a transmission SERVICE, instead of a complete rebuild.
