Travel supreme air bags won,t inflate, jacks quit
captron33
40 ft. 2006 travel supreme.my airbags won,t inflate, front and rear systems show air pressure are normal. Also my jacks will not deploy auto or manual. When i push the autolevel button the system makes a noise and won,t do anything else, same for trying individual jack buttons. I think these problems are related...any help would be appreciated.
3 REPLIES 3
captron33
So the mobil tech guy and the tech guy at the company determined that the control panel is bad.. PROBLEM is they don,t make that panel anymore. So the work around is another panel and a new box to determine level and some new wire harness I wonder if i can get a used panel???
captron33
I tried setting the null again, did,t help. I will call techs in the morning, thanks John.
JohnnyT
I have the same Equalizer system... There are some quirks... There is a fuse in you electrical bay underneath the driver in front of the tire... Its for the solenoid that activates the hydraulic pump. think there is another near the control panel... That aside you might try setting the null... with the power off press and hold auto level then power up the system. I know this does not make sense but the controller for the system will lock out the manual controls, if it gets or thinks the leveling parameters are outside the engineering specs from Travel Supreme... Your not really trying to tell the system what level is merely resetting it...
Your best bet is to call Equalizer in the morning.. I have found them extremely helpful.
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
