Vacuum Assist Toilet in Pace Arrow
Batbc4
I have a 2008 Fleetwood Pace Arrow 38P that has a vacuum assist toilet. As the pump works and there is no suction I would like to check clamp connections. My problem is not knowing how to access the area I need to check. Can anyone offer some suggestions?
2 REPLIES 2
Batbc4
Problem solved...driver's side slide has to be out and the access is just in front of rear wheels.
janstey58
On my Bounder, also a Fleetwood product, I can access my vac toilet works via a passenger side (same side as the toilet) outside compartment.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
