Vacuum Pump on Southwind
jimroach
Vacuum Pump for Toilets not working on 2012 Fleetwood Southwind, Shut it off for a couple of hours to see if it was just overheated, per the manual, but still won't come on and the toilets won't flush.
Anyone got any ideas?
Thanks in advance
Jim, Bonnie, Dakota and Sapphire
2014 Jeep Wrangler
3 REPLIES 3
happy-2
make sure you don't have the pump switch on while your hooked to city water.if you did you my have blown a fuse.
jimroach
The 12 volts is there. Hoping the pump isn't fried.
2014 Jeep Wrangler
crasster
Check the wires going to the pump & fuses. See if it is getting 12V
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
