W24 chassis with an 8.1 engine intermittent starting problem
JCMack
My mountain aire has less then 18000 miles on it by recently I am having some starting problems. When I turn the key I hear the relays click and there is a draw on the power as all the lights dim (normal when starting) but nothing happens the engine will not turn over so far after several attempts the engine fires up. I am afraid sooner or later I will be in trouble. The battery is fully charged and all the fuses are good. Any suggestions as to what I should be checking? thanks
5 REPLIES 5
bhivetravels
MountainAir05 wrote:
Bad starter or solenoid. Lights should not dim. Too much draw.
X2
Jim and Monica
Maj. USAF Ret. — High School Teacher Ret.
2016 Jayco Pinnacle Ford 350 Turbo Diesel
Full-Timing with Meiko and Marlie:C
rgatijnet1
Try the "battery boost" switch when you start your engine. If it helps, there is no problem with the starter and it may indicate a bad chassis battery or chassis battery connection is the problem.
MountainAir05
edm3rd
Sticking starter solenoid is another possibility.
PF_PM
Could be a bad ground or battery terminals need to be cleaned.
2005 Newmar 34' Kountry Star, 8.1L W22, Blue Ox 10K, Honda Pilot, Bijon Shitzu (Sassy) dash dog. Nine Provinces, Two Territories, 47 States, Northern Mexico... so far..
