water pump help (fresh water)
mhsteve
i have replaced my fresh water pump as it would not pump . new pump pumps water but very slowly . no pressure . need help please .
1997 bounder
34 REPLIES 34
mhsteve
LOL no expert , just dumb old guy ........... LOL
xctraveler
You now know more about your water system than you ever wanted to know:)
Also you get to be the expert next time someone posts a water system problem.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
mhsteve
thanks
hughesjm21
Sounds like your recirc valve used to set pressure is too far open. Not sure what your pump has, but mine has a set screw to set shutoff head and a set screw to set system pressure.
mhsteve
operator error ! got water !! i had one valve backwards ... thank you all .. steve
mhsteve
really plugged now since i tried to clear them ............
mhsteve
no luck again . lines must be pluged . thanks all ... steve
mhsteve
path1 ... thank you also .......... steve
mhsteve
great help . thank you ... steve
xctraveler
If he can shoot water across the street there is adequate flow from the tank to the pump.
If I were going to try air pressure at about 40 psi max, l would apply the pressure to a faucet with the pump disconnected and try to clear it back to the pump rather than driving it further into the system.
I must admit it siounds like a problem I had where a filter disintegrated and blocked up all my inline filters and screens. I even had to replace the T valve under the sink that enables the spray hose. Symptoms are very much the same.
Paul
path1
mhsteve wrote:
well the pump puts out enough to go across the street ! how do you clear the lines with out hurting them ?? ................ steve
X2 on most advice above. You'll find the problem sooner or later.
Being you can shoot water across the street it sounds more like a volume problem to me, probably because of some type of partial blockage. Finding the blockage is the problem now.
Stopping in at our 1 man RV shop many moons ago, he told me of a weird one that I've thought about reading your post.
Our RV guy, after putting in a new pump, checking valves, etc... He found out that the water from fresh water tank to the water pump was not keeping up fast enough. So in the beginning it looked so obvious that the pump or valve was bad.
(I think I remember his story because of the way he found the problem)He told me he didn't have to remove any hoses to find the problem because the water hoses were the newer sort of translucent colored plastic and with a bright light could see a shadow of the water inside the line because it casted a shadow. When he turned on pump, it sucked the water line dry, then water line slowly filled up again. So the problem was really the incoming water line volume did not keep up with the pump.
Long story short it tuned out the customers kids or somebody tossed something in the water fill hole that plugged up the water line exit hole to water pump.
As far as clearing water lines, be careful and not to much air pressure. I don't go over 35 psi when winterizing. Some people put much more than 35 psi, but my limit is 35.
But if you could see that the water is not keeping up with the pump by casting a shadow on the water line with a light your problem is 1/2 way solved.
Why put any pressure to it? Might just lodge something more.
(More interesting was his way of getting the junk out of water tank.)
OK just my 2 cents, hope it helps, especially if you have the newer water lines.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
mhsteve
as in correct way up ? yes i have it correct to the flow . my problem is in all faucets ............. is there a safe way to clear the feed line ? .......... steve
fourmat
mhsteve wrote:
i changed the fresh water filter under the sink . is there more ? thank you .. steve
do you have element in correctly
2009 Challenger
mhsteve
