Water pump problem 2003 Windsport
HPYHILM
No power to pump . No dedicated fuse for pump on fuse panel under bed. No inline fuse for pump I can find. Any body have a idea where a reset button may be or fuse location?
Hpyhilm
NW Washington
2008 Monaco Knight 38PDQ
5 REPLIES 5
HPYHILM
Update Found the right fuse it was mislabeled and was bad. Thanks for your responses.
Hpyhilm
NW Washington
HPYHILM
wolfe10 wrote:
Can you turn on the pump from more than one location? If so, you have a relay that powers the pump. Generally found near the pump.
Pump not working from 2 locations, manual states that there is a reset button but nowhere to be found. I know those manuals are kinda generic and are for several models.
Hpyhilm
NW Washington
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
DrewE
Have you checked the obvious: is the pump switch on? Are the grounds for the pump and the battery solidly connected? Do you have power at the pump control switch(es)?
There must be a fuse or something similar protecting the wiring somewhere. As MountainAir suggests, it very well may not be labeled clearly.
MountainAir05
just check the all the fuses in the panel, Might be hook to hot water heater or any system that has low amp draw. If you have wire tester, then drop the neg cable off battery and no shore power and tone it out.
