โAug-08-2018 04:46 PM
โAug-09-2018 08:55 PM
Tom/Barb wrote:dougrainer wrote:Tom/Barb wrote:
We have the HWH system, hit the on button once, run the jacks down until they touch the ground, hit the on button again, the air will dump. hit the off button.
Standard routine with us, because we do not like our coach way up in the air.
Your HWH system does have a manual mode.
Sorry, you reasoning does NOT make sense. You state you do NOT like your coach way up in the air. But, doing your procedure is exactly what you do NOT want to happen. By lowering(extending) the jacks with Air bags FULL, will level the coach 4 inches HIGHER off the ground. Once the RV is level, you do NOT have to hit the Air dump button. The Air bags will deflate due to the jacks causing the ride height arms to move and auto deflate the bags. There IS a reason that HWH Auto/Computerizes systems DUMP the Bags FIRST, then level. Doug
Not true,, you can level the coach at any hight you like. run the jacks down until they touch. dump the air, and lower to any hight you like.
Lot less stress on the HWH system when running unloaded than carrying the coach up and down..
โAug-09-2018 01:41 PM
โAug-09-2018 08:19 AM
โAug-09-2018 07:44 AM
Another good reason to put the jacks down prior to dumping the air.
1. You NEVER extend jacks with Air in the air bags
2. Doing so, you LOSE 4 inches of lift.
3. Once the jacks hit the ground, your Bags WILL deflate when the ride height arms move from the jacks extension. Doug
โAug-09-2018 07:38 AM
โAug-09-2018 07:11 AM
โAug-09-2018 05:58 AM
โAug-09-2018 04:57 AM
โAug-09-2018 04:31 AM
โAug-08-2018 10:27 PM
โAug-08-2018 09:55 PM
โAug-08-2018 07:05 PM
โAug-08-2018 06:13 PM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
