Why add a sway bar to a DP?
country_sunflow
We are wondering what the purpose of the sway bar, is it necessary?
23 REPLIES 23
country_sunflow
It was an add-on, DH just doesn't think it is needed.
Ivylog
Your 2009 Fleetwood discovery came with a rear sway bar for a reason... not a add on as it needs it. If someone added one to the front and that's the source of the noise you've been chasing, then yes it could be taken off. I would put up with the noise for the increased stability a second sway bar would give assuming it's 1.5" in diameter. If it's less than 1" in diameter, it's not doing much on a 36K lb MH.
If this is to see if it's the source of the noise, then disconnecting the ends temporally is what I'd do, but not remove. A little more info would help.
Upgraded with a 08 HR Navigator 45โ€™...
wolfe10
What chassis, what sway bar-- we really don't have enough info to give you sage advice.
But, very few motorhomes have too LITTLE sway!
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
country_sunflow
wolfe10
country sunflower wrote:
Thanks, DH Wants to take it off. When would you do? Real debate going on here, need to get on the road.
What is the reasoning for removing the sway bar??? And, sure, many DP's have them.
Brett Wolfe
Ex: 1997 Safari 35'
country_sunflow
Should be what would you do?
country_sunflow
Ivylog
Other than the 8 outboard airbag DPs... Prevost, Newell, Foretravel, Monaco/Beaver/HR they all have sway bars on the rear axle to help them from leaning/swaying. Guess you could add one to the front axle if that's the question.
The noise you are hearing could be from it's mountings being worn/loose.
rr2254545
I have never heard of anyone adding one to a DP only gasser
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
