Winegard RV-6004 TV antenna
Craig_Ross
I have a veteran friend whose antenna was destroyed by winds. I dont use my Winegard antenna and was wondering if I could disconnect from my trailer and just hook his coax straight from his TV into it , will that work. His trailer is an old one so it's not like mine
4 REPLIES 4
RLS7201
NOT all Winegard bat wing antennas have amplifiers in them. A lot of trailers have the NON_amplifies antenna installed. You will get very poor reception when using an amplified antenna with out the power inserter (wall plate).
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
dougrainer
If you friend had a Winegard Antenna and he has the Interior Booster wall plate, you can run a Coax from YOUR Batwing to the Cable on top his RV. Connect the coax wires together and he will use his booster to power your antenna, which will feed his TV. Doug
Tom_M1
You can not come straight off the antenna into the TV. You will have to connect to the wall plate inside your RV. The antenna has an amplifier in the head that needs power that comes from the wall plate.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
Sam_Spade
There likely is a "pre-amp" involved in the original setup.
Might work OK, and might not.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
